HI guys, I'm sort of stuck (entry level engineer)
I have a pump system that is meant to be placed in outdoor park environments. This pump and related components are enclosed by a sheet metal housing. I need to cutout the sides and simply mount a basement vent fan into it. Its no problem at all but my only concern is when you have to service the pump or mini compressor inside the unit you must take off the whole housing enclosure. If you take off the whole enclosure then the fan comes off with it making it a hassle to take off because the wires will be connected to the base area still.
How do people usually go about this simple design? I cannot add too much material due to costs and I want to stick to sheet metal as the enclosure.
Any advice would be greatly appreciated!
Thank you
Thank you
