am i to understand that if use a bolted omf "u" frame (for a all window front one (or two) story building) for lateral resistance retrofit (to take the front of the buildiung lateral because there are only windows) i need to use the "tested and accepted" bolt configurations as stated by Fema and other codes (CA)? if so, i cant find a detail for a "T" configuration (beam on TOP of column), attaching the roof (or second floor) to the beam? does this mean i have to use full height colum to roof with beam butting up against column? any ideas or even examples are appreciated. 16 foot high ceiling.. planning of plywood gusseting the webs of 3 trusses and and also a 4 ft wide plywood on the bottom of the trusses (with blocking if the beam doesnt line up with one of the trusses...) a total of 4 columns with 2x2x5 ft deep foundations (preliminary design)
