earthquake loading using of masonry structures using FEA 1
Dear All,
I am looking for leads into literature on comparitive studies on earthquake loading of masonry structures using Finite Element Method and experimantal studies.i.e published theoretical and experimental results of earthquake (dynamic)loading of masonry structures and theoretical results using Finite Element Analysis.
Thanking you in advance for your assistance.
Kind regards
Check out papers by Antelleno De Luca. Or search for De Luca.
Prof De Luca is at the University of Naples in Italy and is regarded as an expert in the field of masonry FEA modelling especially with regard to historic structures.
Qshake
[pipe]
Eng-Tips Forums:Real Solutions for Real Problems Really Quick.
Check also the book by Anil Chopra on Dynamics of Structures, which is an excellent guide on this subject (quite expensive, but worth every penny in my opinion). See here for example.
See also the book of the same name by Penzien and Clough, which is more theoretical but still very good.
See faq569-1083 for details on how to make best use of Eng-Tips.com
