ThePunisher
In Canada wherein our area is subjected to -40 to -50 Deg C, The insulated single core GREEN earthing conductors from the transformer surge arresters to earth are installed hanging from top bracket to the surge counters with insulator support in between.
I am wondering if this is in violation to CEC 2018 Rule 12-102 and Rule 12-120. However, one may also argue that this is earthing (grounding) conductor and not a "current carrying conductor". If there is conductor movement due to continuous very low temperature variation, will it matter if this was grounding conductor?
If the conductor temperature rating is suitable for -40 deg C, will it matter as well?
See attached typical photo
