Q
what is the best / correct method for loop testing ac motor circuits.
ie I need to test some motors fed from an mcc control cabinet
Ive had several suggestions sutch as link the contactor out disconnect at motor terminals & test back to panel
another college says you must test with the contactor energized not linked out. so I don,t know then theres the added problem of some are fed from inverters & I don,t think they would take kindly to a loop test
suggestions please.
suggestions please.
