A small (3MW), remote area power station consists of several generators at 415v (wye) stepped up to an 11kv (delta) distribution system. The 11kv grounding is via an grounding transformer and resistor (10 amp).
If an earth leakage relay was installed with its CT over the 11kv neutral conductor of the grounding transformer, would this provide adequate protection for earth fault ?
If not, what would be a satisfactory solution ?
