I am trying to to Dynamic load cals on deep groove radial bearings. the set-up consists of 4 piston/cylinders hooked up to motor and gear box. Using a crank, two piston are moved to one direction and the two on the other side are moved in the opposite direction. We ran the system at 1500 psi today and two of the bearings failed on one side. how do a do a load calculation and bearing life calc on this?
Thanks in advance.
TSK
Thanks in advance.
TSK
