I was reading this webpage:
And the two blue bulleted points made me pause for a second. He says:
The DCR is always lower than the SCR
The DCR does not change at any time during the operation of the engine
Either one can be explained in the opposite direction. For the first, wouldn't a sufficient amount of boost raise your DCR above your SCR? Say you had a motor that displaced 1cid. Say also that the combustion chamber was 1cid. That would be a 2:1 compresion ratio. If you added 14.7psi of boost, you would have 4:1 compression, which is more than its SCR. Yes? No? (always assuming perfect world, of course).
As for the second, does not the dynamic compression increase as rpm's go up? Say for instance you have a 4" stroke and a real short rod. If the intake valve closes 20 30 degrees ABDC, the incomming air has X amount of time to turn around and escape the cylinder at 1000rpm. If you're spinning your motor at 2000rpm, the air has half the time to turn back around and exit stage left. Does this make sense or am I missing something here?
-=Whittey=-
-=Whittey=-
