rockman7892
- Apr 7, 2008
- 1,176
I have a 60hp 480V motor which is being driven by a 75hp Siemens MicroMaster 440 VFD. The application for this motor is a grizzly feeder (crusher shaker) which presents a high inertia load to the motor. Whenever the motor is VFD is stopped or ramped down, the VFD is tripping on a bus Overvoltage condition. This tripping has become a persistant problem and I need to find a solution.
I wanted to go ahead and install a braking resistor on this drive to dissipate this excess voltage when the motor is being ramped down and regenerating voltage back onto the drive. Can anyone help me determine what size braking resistor I will need for this drive. Is there a formula or some other means of calculating the size of the resistor need for this application?
