DXF to DWG
Juice
62
Is a way to convert DXF files to DWG files?
Juice
Juice,
What version of Acad do you have?
If you have 2000 or above you just open the dxf file as you would a dwg drawing and save it as a dwg file.
If you have an older version you must first import the dxf into a blank drawing and then save it as a dwg file.
I hope this helps you.
Regards, Steve Smith
Product Engineer
Staco Energy Products Co.
Juice,
To import the dxf file into autocad just enter: dxfin at the command line and hit enter. Then do as Steve says and save the drawing.
sc
