Hi!
After i imported a dxf or dwg file into Solid Edge i cannot remove single lines from the drawing - i can only remove the complete drawing :-(( How can i or what do i have to do to work with the dxf file?
Either the Geometry is grouped, or the elements that make up the drawing are in a drawing view. right click on a line and see if you can select "draw in view" this should allow you to select individual elements.
