In NX there is a good chance to estimate the life of any component using the durability application in NX Nastran.
You can run the solver using the linear analysis results or the nonlinear results (sol106) by checking use Non-Linear Results' under 'Solve Options'.
However, when I combined the sol106+durability solver the following warning popup
SOL106 does not have strain results for computing fatigue life outputs
it seems that the durability read only the linear value for fatigue-life calcultion
this question worthy to submit to Siemens if possible as it critical, but even though I use a university license i could not find submit it as they ask for the key which is for the license buyer, not me, its should be at the uni.
any idea would be appreciated
