Duplicate Elements
engltayl
GB
Is there an easy way to assess a model to determine if there are any duplicate elements (i.e. 2 elements lying on top of each other)
thanks
Yes!
One way is to use the command NUMMRG,ELEM,,,SELE. But this works only if the elements are identical.
Another way is to program a macro with APDL, see the commands: *DO, ESEL, NSLE, ESLN.
Alex
This works for shell elements.
Turn OFF element outlines. /edge command
Then do an eplot. Duplicated elements will show element outlines when you have element outlines turned off.
-Dan
