vonsteimel
I was wondering what is likely to be most efficient in a ducted fan. The design of the duct is long, approx 4x the diameter. This is to be used to create thrust, not as a compressor
The option of placing 2 to 4 contra rotating fans/props or...
placing 2 to 3 fan/props rotating the same direction and using stators in between. Each fan/prop would have a different pitch and increasing number of blades as seen on a turbine compressor.
Any info will be appriciated.
