Dual Rating and PSVs
solinar
21
We occasionally run into equipment that was originally stamped at two or more coincident MAWP/MAWTs.
For instance, an ASME Section VIII Div 2 vessel was originally rated and stamped (on the nameplate and data report) for 1500 psi @ 100 °F and 1000 psi @ 700 °F.
How does ASME (or any other authority such as API NBIC etc) address pressure relief on such an item. If you decide to use the 1500 psi @ 100 °F MAWP/MAWT can you set the relief valve for 1500 psi considering the vessel is also rated for a maximum of 1000 psi at a different temperature?
Do you have to provide any type of thermal protection to ensure that the vessel does not exceed its MAWT for a given MAWP?
Any references to areas of API ASME NBIC etc. such as interpretations would be greatly appreciated.
I encounter the same on ansi valves,
designs are for its intended use an dthe dual cert makes a lot of sense to caution the user.
genb
