Dual Media filter vs Pressure sand filter
kwisatz_haderach
IN
Hi guys, please help a novice learner understand which is best. We have a requirement for filtering surface water that is high in TSS (around 100 PPM and trubidity (30 NTU). We contacted three suppliers and one has given pressure sand filter (PSF) followed by activated carbon filter (ACF), while the 2nd supplier suggested to go with Multi grade filter filled by ACF, while the third one has suggested Dual Media filter followed by ACF. Three suppliers are telling me that theirs is the best solution for our requirement. I can't able to choose between them. Please help. Based on your experience which you will choose?
Get a chemical engineer involved!
Sand filter is for raw water, coarse filtration, AC filter is a polishing filter.
Note: AC technology is good for Hydrocarbon removal, but you need to be able to regenerate/dispose them
Good luck
Pierre
No, this is just for our factory usage. First we are using ground water that has less TSS and turbidity, but due to local govt restrictions we have to use canal water now, which is high in these values.
ok, for reuse in the factory?
I suppose it depends on what your final requirements are, we use silt stopper aka "lamellas" for our site sediment control during wet season, basically a flocculation system (and i think dosing is an option). This may be all you need
https://www.trenchmate.co.nz/wp-content/uploads/Trenchmate-Siltmate-SM50-spec-sheet-2023-V3c.pdf
There are numerous stormwater devices that we use as well that use filters, but those would be via gravity flow (google Spel filters, stormwater360)
