That makes more sense, but I don't believe the economics (life cycle costs) support such a system.
The condenser needs to be in the RA side so the heat from the furnace isn't actually absorbed by the condenser.
I used to own an all-electric house with heat pump/resistance assist, in a neighborhood with gas service. I cast about for a solution to astronomical heating bills and poor performance that retained the heat pump. There was nothing that was economical considering the first costs (even solar assist/storage systems at a time when there were huge tax credits). A high-efficiency gas furnace was the solution.
In Ralph's case, you can retain the HP in a boost configuration ahead of a furnace, if you think it is in good condition and electricity @ SEER is cheaper than gas heat (per BTU delivered), which is the case in some areas. Or just use it as a central A/C system. Either way I suspect you'll end up buying a gas furnace capable of handling the full heating load, which is what spoils the economics.
