Dual Dimension spaces
  • Thread starter Thread starter dans
  • Start date Start date
D
dans
Guest
Can some please tell me how I can get rid on the spaces when using dual dimensioning (MM) and (decimal) I know that I can change it to be to the right under prorerities but what I need is one on top of the other (see picture)
There is a way to do this, but it has a small disadvantage, it will put a line between the two dimensions, if you can "live" with it this is the solution. Set this option to iso_ something, there are 2 iso options.
And it will look like this:
Don't know if you can get rid of that line between the dimensions.
