DSAW PIPE DETAIL -
CREERAAM
109
Hai,
DSAW pipes mentioned in the API 5L standard is that two longitudinal weld seam must be at 180 deg?
REGARDS,
G.SRIRAM.
Dream,Dream,Dream Dream transforms in to thoughts.And thoughts result in action
Yes, see 8.7 of the specification.
The devil is in the details; she also wears prada.
However, don't confuse DSAW with double-seamed pipe.
DSAW is welded from the inside and outside of the pipe.
Double seamed pipe is two longitudinal welds, 180 deg apart.
DVWE
Thanks for the information. So the DSAW pipe is meaning the two types LSAW PIPES and SSAW PIPES?
REGARDS,
G.SRIRAM.
Have a read of 8.6 of the specification.
Having been on the API 5 committee ( long ago) , I don't remember DSAW ever being discussed as being pipe with two weld seams.
DSAW doesn't exist in API Spec 5L. The term "double seam pipe" does.
Steve Jones
Corrosion Management Consultant
All answers are personal opinions only and are in no way connected with any employer.
"The only limits in life are those which we impose upon ourselves."
No BS, you're not senile. Your in that forgetful stage that comes first that I can't remember what they call that ...
P.E. Metallurgy
SSAW Pipe some may call DSAW pipe?
Thanks for all for sharing.
REGARDS,
G.SRIRAM.
Perhaps, but SAWH (Helical) some may call SSAW (Spiral).
