hawkaz
- Oct 28, 2010
- 416
Does anyone have literature on causes of drywall cracking at exterior steel stud walls?
I have a building that was designed 5 years ago; they have over 180 minor drywall cracks throughout the structure. The stud deflection under max. wind load for the area is h/400. Most (but not all) cracks occur at window corners and stairstep up following the drywall joints. Most of the cracks are on the exterior walls. Some even occur in drywall that was installed on top of plywood shear walls.
No cracking is noted in the stucco on the opposite side, no cracking is seen in the stem walls. Cracks have been patched numerous times, but keep re-occurring. Expansion joints have been installed during the on-going repair process.
The owner, architect... are frustrated that the repairs aren't holding, and they insist the cracking must be due to stud movement. Since the stucco isn't cracking, I am having a tough time agreeing with this. I suspect sub-standard workmanship and poor patches, but can't back it up.
Any help in finding causes for this type of cracking would be appreciated.
