warrenelec
I need to help design a drying oven for some parts. Unfortunately, I am not sure where to begin. We manufacture electric heaters , so as a cost saving measure are attempting to design an oven to dry heating elements and manufacture it in-house. I can calculate what is needed for heating requirements and a control device, but i'm unsure what to use for insulation. I also don't know about ventilation to remove moisture in the oven. The oven currently used is not really airtight, so the moisture isn't really a problem, however I don't know if this is the best idea for a new design. The basic plan of action is to use steel beams as a frame and have insulation enclosed in sheet metal and attached to the frame. The Oven runs at about 275-300 degrees F. Any help at all with this is greatly needed and appreciated.
Warren
Warren
