Dry to wet basis
AndreChE
Chemical
PT
Hello
I am doing energy balances to cracking furnaces.
I have the %vol O2 at dry basis and I want to convert it to wet basis.
What is the best way to do it?
Thank you
AndreChE
AndreChe,
Do you know that dry flow or the wet flow rate as a total? If it's dry flow and you also know volume of water vapour then it's easy just recalc the % by determining dry volume flow and dividing by new humid flow rate.
If it's a wet flow then you need to calculate the volumetric ratio for your stream which can be done from knowing pressure, T and humidity ratio, or if you know water vapour volume flow. You can directly correlate the dry flow rate from this data and using this recalc your %O2 as a wet basis.
I don't know any other way that's easier I'm afraid. I have a thermal balance calculation spreadsheet that I use for enthalpy calculations in my absorption column calculations if you have traouble I can copy the relevant section of the calcs and send through to you by email, let me know how you go.
Cheers,
K.
AndreChE:
To convert the concentration of a gas component from a dry basis to a wet basis, you must first know the water vapor content of the total gas:
wet basis concentration = (dry basis concentration)(1 - w)
where:
wet basis concentration = volume %, volume fraction, or ppm by volume
dry basis concentration = volume %, volume fraction, or ppm by volume
w = volume fraction of water vapor in the total gas
Milton Beychok
mbeychok@xxx.net (replace xxx with cox)
(Visit me at www.air-dispersion.com)
