I would be grateful if you could assist me with a short response to the following queries:
• Is automatic mechanical seal failure trip (either primary or secondary seal) implemented on pumps that are handling hydrocarbons of C5 or lighter fractions?
• Is it normal practice to monitor the health of both the primary and secondary seals on a continual basis?
• If the trip is not automatically initiated what is the operations response philosophy? E.g. alarm only, operator attends and manually shutdown pump.
• If a trip is initiated does it only stop the pump or are the isolation valves closed as well?
• On compressor dry gas seal systems is a trip automatically initiated on primary seal failure?
• On compressor dry gas seal systems is a trip automatically initiated on secondary seal failure?
• On compressor dry gas seal systems is a trip initiated on failure of the separation seal?
• Does the response to the queries above differ between onshore and offshore environments?
