Hello all,
I am writing to ask advice on some equipment I want to specify and later purchase. Any and all comments would be very much appreciated. I am an electric power engineer, so this project of mine is a bit out of my league.
I would like to have built for my company a portable air drying system. Specifically, an air compressor supplying an air dryer. The output needs to be very dry breathable air, with a dew point of less than -80F, a flow rate of about 24SCFM at a minimum pressure of 50psi. This air will be used for allowing my employees to breathe safely and at the same time maintain a very dry environment inside of a large work area (10,000 gallons enclosures).
Here are some questions:
1. Could you recommend a very good company for the air dryer itself? The mode of drying should be heatless, regenerative desiccant-type. I am looking for quality and reliability. Presently I am looking at the ZEKS Company.
2. In addition to the air compressor and air dryer, I am being advised by others that the air should be "scrubbed" so as to remove any CO, odors, oil mist from the compressor, etc. Can you provide a high quality vendor for these items? ZEKS provides air dryers with special filters, etc, for these pollutants. Example: ZEKS CDP034
Again, my goal is to buy high quality equipment that also may have minimal maintenance requirements.
Thanks in advance or any help you can provide.
Chris
Chris
