Hey, guys. I hope this is a good place to as this, I'm having trouble finding an answer. Basically, I'm trying to make my own drum pads, and I'm trying to figure out what kind of material I need. If any of you are familiar with the cheaper electric drum kits out there, you'll know they often use some kind of rubber with a transducer inside. I basically need a material with decent stick bounce (though not too much), good durability (i.e. will last more than a show or two), and can either be molded or machined into the proper shapes. Here are a few links to get an idea of what I'm on about.
Typical kit:
http://itsaboutelectricdrums.com/fil...drum-kit-2.jpg
This is closer to what I'm trying to do:
http://www.musiciansfriend.com/drums...ar-trigger-pad
Thanks for the help,
Christian
Typical kit:
Christian
