I'm double checking sight distance for a drive adjacent an overpass of an expressway. Drive is on the overpassing road right off the bridge approach, and can't be relocated.
The typical intersection sight distance has the car set back a certain distance from the crossing road 15' or so while it waits to enter the main road.
Is it safe to assume at the private drive the vehcile will pull up as close to the intersection road as possible to see (esp. since they are used to pulling out of their drive?), if so how far can I assume the driver's eyen be back from the edge of the road (IOW whats the typical horizontal dimension used from front of car to the driver's eye)? I have heard 8' but want to confirm what others use. I am in Ohio.
TIA
Dan Ficker, PE
TIA
Dan Ficker, PE
