Driveshaft/halfshaft design 1
amorrison
CA
General question.
Why are driveshafts/halfshafts engineered the way they are?
Say for a 100-200hp vehicle(2wd or 4wd)the driveshaft to the rear diff is ~1.5inch in diameter and hollow while the halfshafts to the front wheels of a 2wd are ~3/4 inch in diameter and solid. The larger hollow shaft has less torque load than the smaller diameter hahfshafts.
Length?,wrapup?,material?,rotational jerk(impact loads)?
Critical speed.
Mike Halloran
Pembroke Pines, FL, USA
incidentally both your estimated ODs are very small, I'm more used to numbers like 2 1/2 (for a two piece) and 1 1/4 respectively.
Cheers
Greg Locock
SIG:Please see FAQ731-376 for tips on how to make the best use of Eng-Tips.
Thankyou Greg.
I was hoping a guy like you would also answer the gist of the question. (;<))
Mike's point was entirely right, propshafts are (often) designed for whirl, halfshafts for torque capacity. Halfshafts are often made from the well titled axle-steel, whereas you can make propshafts from aluminium, steel, MMC or carbon fibre, and no doubt there are other examples.
Cheers
Greg Locock
