mizzoumech
- Mar 5, 2012
- 2
I am currently looking into designing a 4 wheeled car that will lift steel coils and transfer them to a different location. The following parameters are as follows:
Wt of Car w/Steel Coil: 125 kips
Velocity = 6 in/sec
Distance = 50 ft
Drive Shaft Dia = 3 in
Coeff of static friction (stl to stl) = 0.78
Wheel Diameters = 12 in
The car wheels will be steel and will be riding on steel rails. The drive system will consist of an electric motor with a shaft mounted reducer. The back car axle will be the drive axle. I am assuming that I will need to calculate the torque and power required to move the car from a static position. This would include overcoming the weight of the car as well as the frictional force from the steel wheel to steel rail contact. I believe I need to look at the total weight of the car when I am calculating the reducer torque. Is this correct? Is there any other item(s) that I need figure?
Velocity = 6 in/sec
Distance = 50 ft
