jchanna
- Mar 10, 2016
- 2
Objective:
Drive multiple hoists utilizing one motor.
Description:
Our industrial space is outfitted with multiple joist-mounted hoists for loads of 50-150lbs each. Each rope-wound pulley terminates at a single control wall, where they are lifted and lowered by hand. We would like to convert this manual system to a semi-automatic cable system and add a motor controlled by a switch box. The motor would power each hoist asynchronously, controlled by the switch box.
Questions:
What type of motor head would drive several different cable-wound pulleys independently and asynchronously?
Who might manufacture a switch box that could control this system?
I'm not sure if this is the correct forum for this; in fact, I'm not even sure I'm asking the right questions. I was hoping one of you could direct me to the correct equipment or resources needed for me to start to narrow down what it is we're looking for. Also, any help with the correct terminology would help me zero in on search, so far several hours on Google have been fruitless. Any direction would be a huge help. Thank you in advance.
Description:
Questions:
