christopher128
Computer
Goal: Drive a cep_2242 piezo buzzer from a 3.3V FPGA output. Driving direct from FPGA does not generate the required sound volume, not surprising considering the buzzer operating voltage is 3-16 Vdc (7mA max at 12V).
I would like to use an integrated load switch, so I can provide 12V to the buzzer and on/off with the FPGA output.
My question is: Can someone recommend a load switch which will work with the 7mA max current drawn by the buzzer?
Maybe similiar to the FDC6324L (Vin 3-20V range / on 1.5-8V) but with a much lower load current minimum when on.
Thank you,
Chris
Thank you,
Chris
