Drilled Shaft Tip depth beyond fixity depth
minorchord2000
226
After determining the depth to fixity for a concrete drilled shaft, what is the rule of thumb (if such a thing exists) for the increase in depth beyond fixity to the tip elevation?
Same question posed in the foundation engineering forum. Please do not double post.
If you've used the fixity method where the depth to fixity = 1.4*R (clay) or 1.8*T (sand), the method is valid for embedded length > 4*R or 4*T.
