In drilled pier design for compression loading, and in fairly uniform alluvial soils, I typically follow the FHWA recommendations for limiting the length:diameter ratio to be less than 30, adopting the rationale that load transfer below this depth attenuates.
Beyond the 1999 FHWA Drilled Shafts Manual statement that "A good rule of thumb is that the ratio of length (L) to diameter (B) of a drilled shaft should be 30 or less", does anyone have any references or experience in adopting OR exceeding this design length limitation?
