JD80
- Feb 27, 2008
- 43
I'm trying to set up a Design Table for a sheet metal assembly.
I'm having problems with the Drawing Views not updating correctly. The design table is set up to control the gauge (thickness) of the metal based on height (I've done this with configurations at the part level). The design table specifies the configuration of the part. The assembly updates the thickness of the metal correctly, but the drawing does not.
This is an issue because even though the formed dimensions are correct, the flat view (used to program the CNC machine) is not correct. In the drawing even if I select the " 'in-use' or last saved" option the part doesn't show the correct thickness. How do I get the part to update in the Drawing View? Even if I get the drawing to recognize the updated part how can I get the correct flat pattern?
