I'm currently running NX2.
The recent number of posts regarding drawing templates and parts lists has inspired me to streamline our workflow. However, I have run into 2 problems (so far):
1) when I setup the template file, I added some standard views at 1:1 scale; but when I use the template the views come it at 1:4, 1:2, and even 4:1 scale. I have tested with multiple sized parts, and even those that would fit comfortably at 1:1 scale don't come it at 1:1. What controls the view scale? How can I get it to default to 1:1?
2) I have added a column to the parts list to show the part number (for me, the part number is the file name - eg "13579.prt" would show as "13579" in the parts list). I am using the system generated attribute <W$=@$PART_NAME>. It initially shows up as a square with a diagonal line through it, I have to go to "preferences" -> "assemblies" and change the "Part name style" from "description" to "file name" then update the parts list to get it to show up properly. This works well until I close UG and reopen it (it must be a session setting?). Is there a way to make the "file name" option the default? I glanced through my environment settings file, but did not find anything that looked useful (not surprising since I don't know what I'm even looking for). Is there an easier way to get the part number in the parts list? If we have to change the preference setting each time it will lead to confusion among my coworkers and mistakes on the prints.
Also, will I be able to use my custom .pax files (NX2) in later NX releases? Rumor has it we are upgrading soon to NX6 but I'd rather not wait around for that.
