You can either use Cartesian or Polar coordinates.
Either way, Format Length and Angle Units as you want to work. I work in decimal Length and dms Angles, as that relates to deed plots easiest. Then pick your starting point. Then:
Cart.: @2,3 goes +2' in X and +3' in Y.
Polar: @2<2d15'30" goes +2 at the bearing described.
