Drawing Parameters
  • Thread starter Thread starter Sudharshan123
  • Start date Start date
S
Sudharshan123
Guest
Hello Friends,
I have one question regarding parameters.
Pro/E part is having certain parameters like Description, File Name ,Weight, Volume etc.
I will now create a drawing of the part. In tools parameter, there are no parameters.
Question is
1. Certain parameters values should be same in both Part and Drawing like Description value and File Name vlaue etc. How to make drawing automatically fetch these parameter valuesfrom the part ? It should be such that, even If I change the description in drawing, it shuold change in part and vice versa. This case is assumed template used for drawing is not having any parameters defined for the template, it is empty.
2. Assume I have created the parameters in templates and when I open the drawing, it will come with parameter template, how to pull the values of parameters from the part parameters ?
Appriciate if anyone can lemme know how to achieve this.
Thanks, SM
If the parameters are in a note in the format, when you create a new drawing using that format, it will pull the parameter info from the model.
