Drawing option for detailed text
  • Thread starter Thread starter KK_designer
  • Start date Start date
K
KK_designer
Guest
I´m searching for (maybe) parameter wich will display "Detail AA" instead "Detail A", i just wanna rename it :). I found one wich control text "See detail X"
and it is:
detail_circle_note_text = default,
and if I change "default" in to other text, example "just see detail", it will apply on drawing when I´m making detail view:
detail_circle_note_text=just see detail,
only issue is how too change text on detailed view (Detail X)??
Is there an option?
Modification of detail view callouts is accomplished using edit value and then selecting the text portion ie "A" and typing in "AA".
In Creo select the magnify glass and type in value and select the resultView attachment 6277
Highlight the detailed view & select properties. Change the view name to AA
Thank You neilb and robertib,
what I´m trying is to change value in .dtl file (metric.dtl). I change one "detail_circle_note_text" in "just see detail" instead "default", so every time when I call insert detail it will automaticly apply attached text "just see detail".
My apologise because I didnt say that I´m on WF5 and some time on WF3. And on both I need this...
I´m interesting about your suggest neilb, but where I can found this magnify glass, where I can tipe value, and if it is on WF5, will be next time automaticly applied when I use it?
Your suggest robertib, if I understood correctly are applied in session and only on one drawing, and when i wanna to use next time will be not applied automaticly?
By the way I had tried and I can´t edit nothing inside dialog box (note properties > text > DETAIL [1:&VIEW_NAME .....]). I´m talking about text on detailed text not for attached text with arrow.
I said "In Creo select" Your are in WF5 there selet Edit then Value!
