Drawing linkage changed from CATPart to CATProduct 3
CAD2015
Automotive
I need to modify a drawing link (from a CATPart pointed document to a CATProduct).
How could I do it?
MZ7DYJ
search forums... only way is by script but you're likely to lose all dimension links.
Eric N.
Thanks!
MZ7DYJ
While in the drawing, Try: Edit -> Links.. --> Click on the link you want to change --> Replace --> Select the CatProduct you want to link.
itsmyjob is right though, you will probably lose your dimensions. Depending on how many you have, it may be simpler on the brain to just start fresh with a new drawing. Good luck.
Robert Neuman
