S
sTaLa
Guest
I'm from Pro/E and pretty new to Solidworks. I am experiencing some problems.
1. Whenever I dimension a diameter from the outside of the circle (arrow pointing towards the center), I have a line crossing the circle. I only want an arrow ending at the edge of the circle, no line crossing it.
2. Whenever I add tolerances, the nominal dimension is next to the lower tolerance. I want it in the middle of both tolerances.
3. How do you break a line? I tried the "trim entites" option but it did not work.
I played a lot with the options and managed to solve a lot of my first problems. But I am stock with the ones I mentioned above. Can anyone help me?
Thanks a lot!
Thanks a lot!
