hydroponder
I am rebuilding my garage and am wondering what is the ideal depth to place the draintile. The existing garage is completely demolished and I am getting concrete today. I have an alley garage and I walk about about 6 feet to my back yard to the east. The north wall will also be buried approximately 6 feet. I also have a wing wall on the south wall that heads approx. 6 feet east toward my house that will be used for the steps. I am planning on placing draintile along this wing wall, then along the east wall and also along the north wall and then daylighting it to the alley at the northwest corner of the garage. See the attached PDF for a better idea of what I have going on. I am wondering what depth I should place the draintile. A couple things to consider: the alley at the northwest corner is about 1 foot above slab grade and this is the only spot I can daylight the draintile. Should I place the draintile as low as possible and then use crushed stone (or pea rock?) filled up all the way to near ground level? Or just use about a foot of crushed stone? Or, am I better off placing the draintile a couple feet below grade?
To me, I think I should place the draintile as low as possible, and then fill a 1 foot trench with crushed rock up to about a foot below finish grade. Then I will probably put some fabric over the rock and fill the remainder with topsoil for a planting medium. Can somebody either confirm this or recommend a better solution? Thanks.
