FTank
- Jan 24, 2007
- 29
Has anyone had experience with a "drain dry" system for a conical floor storage tank. I believe the idea is to slope the tank floor to the center and run an outlet pipe from the side of a sump which would be installed at the low point of the cone, thru the tank pad (sand & gravel construction) and terminate in a 150# connection flange.
The tanks are 191' Dia. so the piping would have to run approx. 95' horizontally thru the pad. My concerns are:
1. Centre column support for roof rafters would be located inside the sump. (or sump c/b located off center to avoid this.
2. Loadings on the horizontal, buried pipe running thru the tank pad.
3. onstruction of sloped gravel/sand tank pad.
4. Etc., etc.
I checked API 620 & this is not addressed there.
API 650 Appendix "O" - covers under-bottom connections for flat bottom tanks so I'm thinking I could use this as a guide. But I'd rather borrow on others' experience if you've run across this before.
4. Etc., etc.
