DRAFTING TABLE QUESTION
mymylepire
Automotive
Jan 4, 2007
27
I would like to know if it is possible to put a line across a box of a table, so the line links 2 opposite corners ? I have to draw a line everytime and it is not link to the corners. When I modify the table, I have to redo these lines.
Myriam
solutions :
1) do not modify the table dimensions
or
2) create a detail view with a line like you need
insert the view in the cell of the drawing table with right clic.
Problem : the picture will change size according to width but ratio (width/height) will remain -> line will not join opposite corners...
solution : set autofit for the ROW
Eric N.
