Hey all, this should be a fun one. I have a drafting machine that I intend to repair. Some components work, and some don't:
[ol 1]
[li]Probably a horizontal slide stop. Does not work[/li]
[li]Embedded metal plate that slides. I believe that 2 locking screws are missing.[/li]
[li]Working vertical slide stop.[/li]
[li]Dial lettered V at current location, lettered H at 270 degrees.[/li]
[li]Working rotation lock.[/li]
[li]Some sort of lock.[/li]
[li]Toggle switch on the handle.[/li]
[li]Dial 5'-5 degrees. I assume this is a memory device.[/li]
[li]I can't count. Call this a placeholder.[/li]
[li]At the top, there is a working switch to calibrate the vertical angle.[/li]
[li]There are strings below, which are probably related to 1 and 2, but are too loose to be effective.[/li]
[/ol]
This is an open ended topic. The goal is for better definition and to repair it, but I don't think that should limit the discussion.
I also have acquired an electric eraser, which is awesome.
[ol 1]
[/ol]
