Draft
  • Thread starter Thread starter caylianr
  • Start date Start date
C
caylianr
Guest
When using the Draft feature in Pro-E it removes material. Can something be done to create Draft without removing material?
Can u please elaborate on ur requirement.Draft feature adds or removes material depending on the draft angle .Draft is a manufacturing requirement which assists in easy ejection of the omponent from the mold,Without removal or addition of material i dont think we can create a taper.
Usually the Draft must add material because it is next beyond base geometry. You must to select the correct edge(that hinge), sens, and surface for add material. If you need more help – may by explicit.
i think what caylianr is trying to do is more or less rotate a surface. by rotating a surface, no material would be removed. if this is the case, the draft command is the wrong command anyway. to accomplish this, you could either redefine the creation of the surface in question, or you can actually rotate surface by using the Feature--Copy command or possible the transform command under the surface options.
Try defining your draft direction properly...
http://www.ptcuser.org/2002/
... user presentation: David Low: Creating draft on complex geometry (PowerPoint Presentation 5.4Mb)
adicar01
