Draft view borders
onefjef
Agricultural
Jul 14, 2006
119
Sometimes I have brackets around the draft views. They appear as light grey in the corners. What are they and how do I remove them?
Jef
Jef,
they grey corners denote that the underlying part needs
to be updated.
Check --> Tools --> Drawing View Tracker
for information which parts must be updated.
dy
Thanks,
Problem arose when I brought a model home without using Insight. A file lost its link.
Jef.
It occurs when the links between parts in the assembly have changed. The parts themselves may be up to date but the assembly needs to be opened to update the links.
Also occurs when mass properties of the assembly and sub-assemblies are out of date.
When I update parts I try to do so using edit in place from parent assemblies. On returning to the parent assembly I would then do CTRL+U to update all relationships, followed by a mass prop calc.
bc
