Draft settings altered
karmoh
Industrial
AU
Hi Guys,
Can anyone help?
I was messing with importing an AutoCAD drawing that needed to be attached to a draft. But since then my standard draft environment (for all drafts) has altered and I’m not sure how to get the settings back.
Namely line options is grayed out and the selection grid has changed to a multi-coloured version. see attached PDF
It is as if my normal draft environment is acting as if it is in "draw-in-view" mode
Cheers
No worries guys solved from GTAC
Line style in ribbon bar is grayed out.
SOLUTION/WORKAROUND
Resolved by deleting the Detail folder in the Solid Edge registry
(HKEY_CURRENT_USER->Software->Unigraphics Solutions->Solid Edge->Version
20\Detail').
