draft analysis in wild fire
  • Thread starter Thread starter ecsreeni
  • Start date Start date
E
ecsreeni
Guest
hi
anyone can explain the draft analysis in proe wf2, 1'm not getting
good result, confusing
thanks
sreeni
Hi sreeni,
open the part.
go to->analysis->Geometry->draft
draft dialogbox opens,
in analysis tab select quick and in definition tab click on surface and now select the surface u want to check th draft( to check forentire model select solid geometry in quary selection)
in dialog box click on direction and now select the surface on the same model ( surface should be normal to ejection direction).
set the max draft angle.
thats all.
Hi ram
thanks, it is workinng,
thanks
sreeni
