Dowel Size for Pavement ~ K = modulus of dowel support
hetgen
Hi All,
Is there an empirical formula to calculate K0- modulus of dowel support for a given dowel and concrete type? or maybe a table for typical dowel used in a rigid pavement?
K0 - the reaction per unit area due to applied load when the deflection is equal to unity. I can only find a range figure (300-1500 -ksi/in)which doesn't help to size a dowel.
The stress on the concrete from the dowel is directly proportional to K0and the dowel deflection. So if for example, the dowel deflection is 0.01in using the range of figure the concrete stress could vary 3000 to 15000 psi?
Many thanks.
