Door Flip Dynamic Block Trouble.
mfleming
I have almost fixed this. There is only one Flip that doesn't seem to be working. The Flip Door Swing. It works when I just flip the door swing but if I try and stretch the door opening after it is flipped it gets all messed up. Can anyone help me out I have no idea how to fix this?
In the Samples folder there should be an drawing named: Architectural - Imperial.dwg in that drawing is a block called: "Door - Imperial" which does a good job at what you are attempting to do.
Tracy Lincoln, TLConsulting Consulting, Design & Training Specialist
Autodesk Discussion Group Facilitator
Discussion Group Index:
