Domestic water tank sizing 1
mirza057
SA
Guys,
Can you please let me know any reference(code) for domestic water requirement per person for sizing the domestic water tank.
From a plumbing code perspective, there are no requirements.
I have attached the information I have used for guidance for gallons per day usage per person in different types of buildings. It is based on information provided by AWWA.
 http://files.engineering.com/getfile.aspx?folder=207a8bdc-5740-45cc-9313-5d23187e5e72&file=WATER_USAGE_BY_FACILITY.pdf
usage and storage requirements are not the same. there are a number of other factors that would influence the amount of storage you want. primary ones are fire, emergency and to handle peak flow times where your water production source cannot provide a high enough flow rate
Peddarin,
Thank you, can you be more specific with the information source from AWWA.
